How do I shrink the side margins so that my text automatically wraps to next line?
  • 4 views
  • Last reply by Zenos
Right now, the text just runs off the right edge of the screen, rather than wrapping. So to view the text, I have to slide right. It also prints the same way so I miss out on text that's not showing on the screen.
Would you like to send me an example of such a message? Forward it as an attachment.
The last time I looked at one of these, it was due to some bizarre formatting applied by the original sender. Thunderbird was simply obeying the instructions encoded into the message.
xenos @ gmx . co . uk
Modified by Zenos
